siph
Automotive
- Aug 28, 2003
- 2
Quite a while ago I asked about changing the common name of a part outside of Intralink. At the time no solution was found. I believe I stumbled upon the solution for this problem. It occurs when you take a part and save it as something else. The common name of the new part is the same as of the original part.
The solution: file>rename>in session. This makes the common name accessible for renaming. After that just save the part file.
I hope this helps someone out.
