Feb 20, 2007 #1 dblcrona Mechanical Joined May 29, 2002 Messages 64 Location US Is it possible to dimension an angel x distance chamfer with a leader note instead of an angle dimension and a distance dimension? Thanks, Dblcrona
Feb 20, 2007 #2 CorBlimeyLimey Mechanical Joined Nov 5, 2003 Messages 15,292 Location CA Go to Tools > Options Document Properties > Detailing > Dimensions > Leaders and select Overide standard's leader disply then select the option of choice. Upvote 0 Downvote
Feb 20, 2007 #3 J-C Mechanical Joined Sep 8, 2003 Messages 1,066 Location US Select the dimension tool, then right click and select More Dimensions and select the Chamfer dimension tool. Jason UG NX2.02.2 on Win2000 SP3 SolidWorks 2006 SP5.1 on WinXP SP2 SolidWorks 2007 SP2.1 on WinXP SP2 Upvote 0 Downvote
Feb 20, 2007 Thread starter #4 dblcrona Mechanical Joined May 29, 2002 Messages 64 Location US CorBlimeyLimey, I tried that but when I select the feature to dimension it, it still shows up as two seperate dimensions. Dblcrona Upvote 0 Downvote
Feb 20, 2007 #5 CorBlimeyLimey Mechanical Joined Nov 5, 2003 Messages 15,292 Location CA Oh ... you meant when using the Insert > Model Items method? I don't think you can. Upvote 0 Downvote
