Can someone explain exactly the meaning of this callout on a print or point me in the direction of the standard?
At first look it is specifying a chamfer with size of 0.5 to 0.13mm but does it mean a 45deg chamfer? if so, what is the angle deviation allowed? or is it just a corner break that falls between a 0.13mm chamfer at 45deg and 0.5mm at 45deg?
Any help would be appreciated, we have exhausted our resources here and are trying to be very thorough in meeting the print in its entirety. We can not locate it in the ASME Y14.5M standard.
Thank you.
Thank you.
