We are currently using condensing water from our chiller to cool the building (flight similators) hydraulic system. Our Thermal Storage project called to add new PHE (Frame & Plate Heat Exchanger)to cool the same hydraulic system.
Problem:
1. If we are going to install new PHE, that means rearranging new piping to support with new PHE.
2. If we are using existing condensing water to cool the hydraulic system, the current system peak its condensing capacity so there is a chance to receive shortage of cooling.
3. We are happy with the PHE design, only problem, in about 1.5 year, this whole hydraulic system will no longer be in use in this building. Then we have to dismantle the piping and PHE, plus we have to maintain the PHE while it is in operation.
What do you think? Which is the best approach? Keep the design or to make a change order requesting to keep the original hydraulic cooling system with condensing water? What are your analysis as far as cost, efficiency, and/or design?
Thank you very much for reading.
Problem:
