J
jraquet
Guest
Does anyone know some efficient way of modeling a chain and sprocket system (like a bike pedal - chain - drive system). If the drive sprocket and follower work (turn relative to each other at the correct rates) that would be fine.
Using a gear pair the parts run in opposite directions (as expected) and we can get it to work with an "intermediary" gear with a 1:1 ratio but this seems like a work around and not a direct solution.
Let me know if you have any info.
