It has been said to me that the efficiency of a centrifugal pump is increased if you increase the suction side head available.
I have to pump 1500 GPM water into an RO system requiring @ 850 psi of pressure, pump is operating @ 2,900 RPM and requires @ 20 psi suction head, so I have to provide a low pressure pump into the suction of this high pressure pump.
So my question.....Does the efficiency of the HP pump increases if you significantly increase the suction side pressure above the required NPSH?
Appreciate any help from pump experts subscribing to this forum.
