CENTRIFUGAL PUMP DRY RUN
As long as it takes for the bearings and/or seals to overheat. In the manufacturer's IOM manual, it most likely states "DO NOT RUN PUMP DRY".
the bearing and seal are now contained in a oiled housing. i get what you mean. thanks.
R.Efendy
