centermarks 1
mmakm
21
Is there a way to place a centermark at the center of an obround slot/hole and not at the ends of the slot were the arc centers are?
Thanks,
Unfortunately no. I usually sketch centerlines and constrain them to the model edge midpoints.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP1.0 on WinXP SP2
I Kluge it. I put a construction circle in the sketch (usually circumscribing the slot length), show the sketch in the drawing, put the centermark on the circle, hide the sketch.
It worked in 2004, I haven't had to use it since so I don't know if it still works.
Thanks for the suggestions. I also submitted an enhancement request. We'll see where it goes.
Thanks,
I've also done the Gildashard thing. Both workarounds get the job done
Add centerline/continuous, select center of arc. Add temp lines to where you want centerline to end, then trim CL to the lines.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
If you use the Slot feature from the Design Library, the dimensions are automatically placed at the centre of the slot. However, the centre is not marked.
[cheers]
Helpful SW websites faq559-520
How to get answers to your SW questions faq559-1091
