centerline, centermark color change by journal
niedzviedz
307
Hello everybody,
I would like to change every centerline (2D, 3D etc) and center mark to specific color, for example 186. I have found some example here Link but there is a problem. For example when I add:
Code:
centerline3dBuilder1.Settings.Color = 186
I receive an error: "cannot convert integer to NXOpen.NXcolor". Any one can help with this part?
I tried:
Dim color as NXcolor = (255,0,0) and also have some errors, so I changed my code to this:
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.Annotations
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
Dim workPart As NXOpen.Part = theSession.Parts.Work
Dim displayPart As NXOpen.Part = theSession.Parts.Display
Dim lw As ListingWindow = theSession.ListingWindow
Dim count As Integer = 0
Dim Color as Integer = 186
lw.open
For each cline As Centerline in workPart.Annotations.Centerlines
    count = count+1
    'lw.WriteLine(count.ToString() & ". " & cline.ToString() & " Type: " & cline.GetType().ToString())
    If TypeOf cline Is NXOpen.Annotations.Centerline3d Then
	Dim markId1 As NXOpen.Session.UndoMarkId
		markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Edit Object Display")
	Dim displayModification1 As NXOpen.DisplayModification
		displayModification1 = theSession.DisplayManager.NewDisplayModification()
		displayModification1.ApplyToAllFaces = True
		displayModification1.ApplyToOwningParts = False
		displayModification1.NewColor = Color
	Dim objects1(0) As NXOpen.DisplayableObject
	for each centerline2d1 As NXOpen.Annotations.Centerline2d in workPart.annotations.Centerlines
		objects1(0) = centerline2d1
		displayModification1.Apply(objects1)
		displayModification1.Dispose()
	next
    Else If TypeOf cline Is NXOpen.Annotations.Centerline2d Then
    Else If TypeOf cline Is NXOpen.Annotations.SymmetricalCenterline Then
    Else If TypeOf cline Is NXOpen.Annotations.CenterMark Then
    Else If TypeOf cline Is NXOpen.Annotations.BoltCircleCenterline Then
    Else
        lw.WriteLine(" -> Unknown Centerline Type")
    End If
Next
Return
lw.close
End Sub
End Module
but i receive an error (memory access violation) in this line:
any help will be appreciated.
With best regards
Michael
Your code creates a display modification object then sets up a loop to process all the centerlines; in the loop it calls .Apply and .Dispose. The first time through the loop, the display modification object is destroyed. If your file has multiple centerlines, the code will fail on the 2nd time through the loop. If you want to process all the centerlines, I'd suggest something like the code below:
Code:
displayModification1.NewColor = 186
displayModification1.Apply(workPart.Annotations.Centerlines.ToArray)
www.nxjournaling.com
Thank @Cowski, it's work like a charm. I also figured it out first problem with NXcolor. I have to use
Code:
centerline3dBuilder1.Settings.Color = workPart.Colors.Find("Red")
It's a pity, that developers didn't implemented "color code" in NXopen.NXColor. I have found some mentions about NXcolor.RGB, but unfortunately I was unable to do it work.
With best regards
Michael
NX uses a limited palette of colors, you cannot assign your own arbitrary RGB values. If you have RGB values, you can find the closest color in the NX palette with .AskClosestColor or you can query the RGB values of an NX color with the .GetRgb method. The RGB values it reports are normalized, so you will need to multiply them by 255 to get the normal RGB values.
Code:
Option Strict Off
Imports System
Imports System.Windows.Forms
Imports System.Drawing
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim theUFSession As UFSession = UFSession.GetUFSession
        lw.Open()
        Dim myObj As NXObject
        Dim myDispObj As DisplayableObject
        Do Until SelectAnObject(myObj) = Selection.Response.Cancel
            lw.WriteLine("object type: " & myObj.GetType.ToString)
            myDispObj = DirectCast(myObj, DisplayableObject)
            lw.WriteLine("color number: " & myDispObj.Color)
            Dim myColor As NXColor
            myColor = theSession.Parts.Work.Colors.Find(myDispObj.Color)
            lw.WriteLine("color label: " & myColor.Label)
            lw.WriteLine("color rgb: " & myColor.GetRgb.ToString)
            Dim red As Integer = myColor.GetRgb.R * 255
            Dim green As Integer = myColor.GetRgb.G * 255
            Dim blue As Integer = myColor.GetRgb.B * 255
            lw.WriteLine("red: " & red.ToString)
            lw.WriteLine("green: " & green.ToString)
            lw.WriteLine("blue: " & blue.ToString)
            lw.WriteLine("")
        Loop
    End Sub
    Function SelectAnObject(ByRef selObj As NXObject) As Selection.Response
        Dim prompt As String = "Select an object"
        Dim theUI As UI = UI.GetUI
        Dim cursor As Point3d
        Dim typeArray() As Selection.SelectionType = _
            {Selection.SelectionType.All, _
                Selection.SelectionType.Faces, _
                Selection.SelectionType.Edges}
        Dim resp As Selection.Response = theUI.SelectionManager.SelectObject( _
                prompt, "Selection", _
                Selection.SelectionScope.AnyInAssembly, _
                False, typeArray, selObj, cursor)
        If resp = Selection.Response.ObjectSelected Or _
                resp = Selection.Response.ObjectSelectedByName Then
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
End Module
I know, NX only use 216 colors. What I wanna do is convert for example color 186 to fit NXcolor -> workPart.Colors.Find("Red") or to RGB values.
With best regards
Michael
The code above takes the color number and reports the NX color name and RGB values.
The .AskClosestColor method will accept RGB values and return the closest color in the NX palette. I know there is at least one example of it on eng-tips, if you want to search for it.
Thanks Cowski, I will dig it closely.
With best regards
Michael
