Center of Gravity
  • Thread starter Thread starter timmy
  • Start date Start date
T
timmy
Guest
When I set up a part and put in the mass properties to enable me to figure the center of gravity in anassembly, which cordinate system do I pick?
Center of gravity of each component in asm calculated base on WCS (default). You can change to any CS by set current coordinate system.
for giving the mass property and other properties of a material what should i do, by which command and how?
Analysis-Model Analysis
