Sub GetXYZofSurfaceCentroid()
'Get XYZ coordinates of centroid and load
'them into array "XYZ"
Dim swApp As SldWorks.SldWorks
Dim Part As SldWorks.ModelDoc2
Dim SelMgr As SldWorks.SelectionMgr
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Dim Feature As SldWorks.Feature
Dim MathPoint As SldWorks.MathPoint
Dim RefPoint As SldWorks.RefPoint
Dim vRefPointFeatureArray As Variant
Dim XYZ As Variant
Set swApp = Application.SldWorks
Set Part = swApp.ActiveDoc
Set SelMgr = Part.SelectionManager
If SelMgr.GetSelectedObjectCount2(-1) <> 1 Then
MsgBox "You must select a single face/surface for this macro."
Exit Sub
ElseIf SelMgr.GetSelectedObjectType3(1, -1) <> swSelFACES Then
MsgBox SelMgr.GetSelectedObjectType3(1, -1)
Exit Sub
End If
vRefPointFeatureArray = Part.FeatureManager.InsertReferencePoint(4, 0, 0.01, 1)
Set Feature = vRefPointFeatureArray(0)
Set RefPoint = Feature.GetSpecificFeature2
Set MathPoint = RefPoint.GetRefPoint
XYZ = MathPoint.ArrayData
Set MathPoint = Nothing
Set RefPoint = Nothing
Set Feature = Nothing
Part.Extension.DeleteSelection2 (2)
MsgBox "X: " & XYZ(0) & vbCrLf & "Y: " & XYZ(1) & vbCrLf & "Z: " & XYZ(2)
End Sub
