I don't know for sure why or if cement dust does or doesn't explode, but the PCA still seems the best place to look.
Here are some other references:
Taken from a Googel search at
Whips and chains
The silo cleaning equipment uses its rotating “whips” to cut the material off the walls. A key to success is matching the flails to the material. Flails of a rubber-covered nylon rope, for example, have proved to work well in coal. These flails can be equipped with “knuckles” to improve the cleaning effect and extend whip life. The knuckles are most often constructed of urethane to provide impact without damage or sparks.
Steel chain is commonly used for portland cement or any compacted material where there is no risk of explosion. Nonsparking brass chain is effective for compacted materials where the risk of fire or explosion is present.
A book reference that looks good, although I haven’t reviewed it:
Dust Explosions in the Process Industries-US-
ISBN:0750676027 (Hard cover book)
3RD Edition
Eckhoff, Rolf K. /Publisher:Butterworth-Heinemann Published 2003/05
