howardoark
Geotechnical
I have a fairly fundamental question about pavement design which I'd like to get some input on. The CBR is conducted on a soaked sample of subgrade material at a specific density - the sample is compacted to whatever you're going to require in the field (say 100% standard proctor) and then soaked because no one can prevent a pavement subgrade from becoming saturated at some point.
In R-Value testing, you make up 4 different samples at 4 different densities and moisture contents and then compress them until they're saturated (saturation evidenced by water being squeezed out of them). The R-Value reported is the R-Value that corresponds to water being squeezed out at 300 psi pressure.
I'm looking at a result now that has an R-Value of 24 at an initial dry density of 107.4 pcf (17.6% moisture content 800 psi exudation pressure) and an R-Value of 2 at an initial dry density of 95.9 pcf (27.3 % moisture content, 165 psi exudation pressure). The reported R-Value is 4.
I can see that using an R-Value of 4 is conservative and likely to represent the worst case. But if I'm going to use the worst case anyway, what's the point in requiring any compaction of the subgrade (other than my earnest desire to spend as little time in the company of lawyers who aren't my clients as possible)? It seems to me that the CBR represents a testing of actual conditions and the R-Value represents some theoretical worst case. Am I missing something important? Not that it matters because I'm in California and have to base designs on R-Value.
And how do they come up with correlations between CBR and R-Value when CBR can be based on anything from 80% of standard proctor to 105% of modified proctor?
Jeff
Jeff
