Since two years ago we experienced, on different V18 diesel engines in our company, pin hole damages on the crank pin of the engines. It is suspected that the lube oil pressure drop to the point that cavitation occur always at the same place. These damages in the engines occur every time at the same place on the crank pin but in different cylinders. The cavitation occur at the lube oil hole in the big end bearing which guide the lube oil into the lube oil channel which guide the lube oil to the piston crown area.
Besides the pin hole damages on the crank pin, the big end bearing also experience scratches in the center of the bearing.
Did anyone experience anything like this before? what could be causing this phenomenon?
Any comment is appreciated.
Thanks in advance
Thanks in advance
