Dears
Kindly, I want to hear from you regarding this topic. The system is closed cooling system.
I believe it is difficult to attribute the sound you hear from centrifugal pump to be a cavitation especially if the discharge pressure is normal.
The last time we had a problem with this system is that the the suction valve was fully closed (we thought it was open).The discharge pressure was normal and there is no sound from the pump. This happens because the suction valve is like a discharge valve that is far away from pump (closed loop). So if the suction valve is closed, there will be no flow and liquid will just recirculate in the pump casing.
If there is a strainer upstream of the pump that is nearly clogged, it may cause cavitation, but only if the discharge pressure is low. then you can say there is a possibility of cavitation.
Now, one of our pumps has a sound (difficult to tell what it is), but since the discharge pressure reads normal, I would say maybe the sound is from the pump bearing.
Please I will be happy to hear from you to know If I have some misconceptions here. Please comment
