Hi All,
I hope i am posting in the right area, if not, then i apologize in advance. I have a bit of a conundrum and reading through this forum there appears to be a lot of very knowledgeable people who may just be able to offer some thought.
I have a brand new 2.0 Duratec engine ( not sure the specific engine is relevant), and it runs and feel fine. The engine in stock trim ( comes with KMS engine management and throttle bodies) should generate 185bhp. Mine generates 160bhp. I only found this out taking it to a specialist engine tuner, who were going to rolling road it, update to better cams and then re-run. They have approx 8 cars ( identical to mine) with the same engine and setup, all produced within a few BHP, 185 and all were 205+ with cams. Mine added about 15 bhp with the cams ( up to 175), but only from 6000 rpm +, BHP actually fell below 6000 revs.
All new parts, identical setup, so naturally they said something is wrong here.
This is what they have checked :
Car was run before and after fitting of cams + springs. Fuel values were setup and checked, and confirmed down on power both before and after.
Ran car on the dyno with silencer removed in case it was restricted or blocked.
Checked position of Crank Trigger
Checked throttle bodies are reaching full throttle
Carried out power runs with varying ignition trims (both plus and minus)
Drained and refilled sump to check correct oil level
Carried out a compression test ( perfect)
Rechecked cam timing, profile and tilt.
So i am stuck and the garage are stuck. They cannot see anything that would make it show consistently down on power, fuelling is all fine, next day they did another car the same as mine with the exact same engine and KMS system, again, perfect 185 stock, 205 after Cams. So there is something funny ( possibly simple) with mine.
I'm sorry this is a rather extended post, i'm really just seeking so advice from experts on what else i should look at, what might cause it to be down on power that clearly everyone so far has overlooked. Any advice of thoughts would be very gratefully received.
thanks in advance
Al.
thanks in advance
Al.
