Catvba Updated constraints
TudorM
Automotive
AT
Hello guys , i am trying to retrieve the updated constraints from a product and delete them , but no succes.
I am new to VBA so please understand.
I have the following script :
Sub CATMain()
Dim productDocument1 As ProductDocument
Set productDocument1 = CATIA.ActiveDocument
Dim product1 As Product
Set product1 = productDocument1.Product
Dim constraints1 As Constraints
Set constraints1 = product1.Connections("CATIAConstraints")
Dim CstUpd As Long
CstUpd = constraints1.UnUpdatedConstraintsCount
CstUpd.Remove
End Sub
Please help ,thank you.
-Trying to understand the language , my first idea was to delete the broken ones and i saw that it is only a property name in difference so i just posted updated ones.
I really tried but still do not know how to join everything...? :(
Sub CATMain()
Dim i As Integer
For i = 1 To my_constraints.Count '-- ok now i have collection of constraints next i need some of them with specific properties : (UnUpdatedConstraintsCount) to delete what do i say next please help?
Next
End sub
Check always the documentation and see the status of your constraints. See also DS examples in that file.
Fernando
Thank you Fernando for your help , it has something to do with this :
and catCstStatusKOBroken , now i am really confused or maybe it's late...
So what i am trying to do is to delete this constraint wich requires update, maybe i didn't explained well....
This morning i tried this :
Sub CATMain()
Dim i As Integer
For i = 1 To constraints1.Count
If (constraints1.Item(i).Status = catCstStatusKOBroken) Then
constraints1.Remove (constraints1.UnUpdatedConstraintsCount)
End If
Next
End Sub
But nothing happens...
Those are different thinks, your image clarifies a little bit more what you want to do.
Just for my curiosity, why you want to delete? Shouldn't be first force update and then delete if it is not OK?
You have to check the status, add to a collection and delete, maybe something like this (I didn't try in CATIA, but maybe you can upload here a sample)
For Each oConst In oConsts
If oConst.Status = UnUpdatedConstraintsCount Then
oSel.Add oConst
End If
Next
Fernando
Hello Ferdo thank you for you response and i am sorry if didn't post right from the beginning, i will try to explain my thoughts :
For example i have done a welded structure like this
and it has a lot of constraints from the begining of the concept (when i started ) after a client review he wants me to do modify some lenghts for examaple and if i am moving elements they are asking for update and if they are like 100 its easier to delete and fix ( if you know what you doing ) . Also i saw that the call for UnUpdatedConstraintsCount property is same as BROKEN ones so i said to do one vba for UNupdated and next one for Broken should be similar.
I will try to implement what you sent, and if i succeed will post here thank you very much.
Hello, i still didn't find a solution tho i am thinking i am close to it :( , please someone have a look,thank you !!!
Sub CATMain()
Dim my_constraints As Constraints
Set my_constraints = product1.Connections("CATIAConstraints")
Dim osel As Selection
Set osel = CATIA.ActiveDocument.Selection
Dim i As Integer
Dim MyCons As Constraint
Set MyCons = my_constraints.Item(i)
Dim iConstraintStatus As CatConstraintStatus
Set iConstraintStatus = MyCons.Status
If iConstraintStatus = catCstStatusKOBroken Then
osel.Add (MyCons)
osel.Remove (MyCons)
End If
Next
End Sub
Code:
Sub CATMain()
Dim i As Integer
    'Set iConstraintStatus = MyCons.Status
        osel.Add (MyCons)
    End If
Next
osel.Delete
End Sub
Thank you for your time but not working
and i have a feeling that it must contain smth. with
o Property BrokenConstraintsCount( ) As long (Read Only)
Returns the number of broken constraints from the Constraints collection.
Example:
The following example retrieves in BknCstNum the number of broken constraints from the myListofConstraints collection of constraints:
BknCstNum = myListofConstraints.BrokenConstraintsCount
o Property UnUpdatedConstraintsCount( ) As long (Read Only)
Returns the number of unupdated constraints from the Constraints collection.
Example:
The following example retrieves in UnUpdCstNum the number of unupdated constraints from the myListofConstraints collection of constraints:
UnUpdCstNum = myListofConstraints.UnUpdatedConstraintsCount
Cause i want to do one for UnUpdatedConstraintsCount and one for BrokenConstraintsCount (also i think catCstStatusKOBroken
The constraint is not satisfied because a geometric element is missing. It can happen in an assembly when a part is missing.
) has to do only for broken ones.
Sorry , i am new to catvba , but i really tried and cannot find solution this is last version how i am thinking it should be please have a look :
Please try with below code
Code:
Sub CATMain()
Dim i As Integer
    iConstraintStatus = MyCons.Status 'iConstraintStatus is an enum doesn't need 'set' keyword
        osel.Add MyCons
    End If
Next
osel.Delete
End Sub
Make sure to check osel object count is greater than zero before osel.Delete
-Prasanna
It's just syntax error, you should not use "set" for non-objects:
Code:
Thank you guys , you are the best , helped me a lot ,works very good for broken ones last request how it should be for UnUpdated ones ??
I guess both broken and unupdated constraints comes under "catCstStatusKOBroken".
Prasanna
Ok finally i got it : for Unupdated needed this : {If iConstraintStatus = catCstStatusKOStronglyNotSatisfied Then}
A huge THANK YOU to all of you !!!
