CATIA VBA renaming one item of a selection
jissididi
Automotive
FR
Hello all,
I have an issue in a macro i'm making
I have various geometrical set all of them for different uses
in those Geometrical sets, I created some planar sections and then I want to rename them all "Planar Section.1" "Planar Section.2" "Planar Section.3"...
to create the planar sections, I create them all at the same time using the mesh and all the different planes and creating them by plane.
problem is that if there has been a section created previously, my first created section won't have the name "Planar Section.1"
So i created a selection of all the planar sections in the geometrical set corresponding, used the selction.item(i) to make a for loop and rename them all
but it doesn't work...
here is my idea
Code:
oSelection.Clear
Set oSelection = CATIA.ActiveDocument.Selection
oSelection.Add part1.FindObjectByName("AUTO_MODE_GEOMETRICAL_SET")
oSelection.Search "'Part Design'.'Wireframe & Surface Feature';sel"
iterationAutoMode = oSelection.Count
For i = 1 To iterationAutoMode
    oSelection.Item(i).Value.Name = "AUTO_MODE_GEOMETRICAL_SET_SECTION_" & i
Next
Anyone has a working idea ?
jissididi
Try to use this.
I believe it does what you want.
Code:
Sub CATMain()
Dim partDocument1 As PartDocument
Set partDocument1 = CATIA.ActiveDocument
oSelection.Clear
Dim part1 As Part
Set part1 = partDocument1.Part
oSelection.Search "(Name=AUTO_MODE_GEOMETRICAL_SET* & (CATPrtSearch.OpenBodyFeature)) ,all"
 Next
End Sub
Tiago Figueiredo
Tooling Engineer
Hello again,
Thanks for the post but it was not the name of the geometrical set i wanted to change but the name of the sections which are inside the geometrical set.
as i have for example 10 section in the first geometrical set and 5 in the second geometrical set, i want to change the name of each section accordingly to the geometrical set they are
Thanks again.
I want my planar sections to be renamed with the name of the geometrical set followed by their number (1,2,3,4,5)
As you can see, in the geometrical set named "manual angular geometrical set", the planar sections created begin by 16, I want it to be 1, 2,3 as for the geometrical set "auto mode"
But in your macro you want to rename the sections of the "AUTO_MODE" and the "MANUAL_ANGULAR" or just the "MANUAL_ANGULAR"?
Tiago Figueiredo
Tooling Engineer
both of them
in fact in my macro i can create first the manual ones or first the auto mode ones,
so that It can happen that sections from the auto set or from the manual set are created with a bad name
I would do the following:
1-Select the "Auto" geometrical set
2-Search all planar sections inside it
3-Rename all planar sections
4- the same for the "Manual"
Tiago Figueiredo
Tooling Engineer
What Tiago is saying is something like this
Code:
Language="VBSCRIPT"
Sub CATMain()
Dim partDocument1 As Document
Dim selection1 As Selection
Set selection1 = partDocument1.Selection
selection1.Search "Name=*GS_1*,all"
Dim oselection1 As Selection
Set oselection1 = partDocument1.Selection
oselection1.Search "CATPrtSearch.Plane,sel"
iterationAutoMode = oselection1.Count
    oSelection1.Item(i).Value.Name = "GS_1_Planar_Section_" & i
Next
Dim selection11 As Selection
Set selection11 = partDocument1.Selection
selection11.Search "Name=*GS_2*,all"
Dim oselection11 As Selection
Set oselection11 = partDocument1.Selection
oselection11.Search "CATPrtSearch.Plane,sel"
iterationAutoMode11 = oselection11.Count
For i = 1 To iterationAutoMode11
    oSelection11.Item(i).Value.Name = "GS_2_Planar_Section_" & i
Next
End Sub
Fernando
- Romania
- EU
ok,
does anyone know the search command that would allow me to select the "Planar Sections" instead of the planes ?
something like oselection11.Search "CATPrtSearch.Planar Sections,sel"
(I have tried another way of getting the elements i wanted selected by selecting all the elements of the same type and removing the instances i didn't want
But when I finally have the element I want selected, I get an error during the oSelection.Name method and I don't know why)
btw I am coding in VBA not VBScript
I don't have the license to access Planar Sections.
Try to record a macro where you find those, with the find command. On type select "from element" and pick one of those planar sections.
Tiago Figueiredo
Tooling Engineer
Thank you Tiago
Here is what I found
I tell you if it solved my problem
Sub CATMain()
selection1.Search "CATPrtSearch.SkinFeature,all"
End Sub
Hi again,
So I tried it but unfortunately, the method oSelection.Item(i).Value.Name give me an error....
I don't know How to manage this anymore
iterationAutoMode = 0
oSelection.Clear
oSelection.Search ("Name=AUTO_MODE_GEOMETRICAL_SET")
oSelection.Search "CATPrtSearch.SkinFeature,sel"
oSelection.Item(i).Value.Name = "MANUAL_ANGULAR_GEOMETRICAL_SET_SECTION_" & i
Next
Another thing
I just tried to run my code selecting the planes instead of the planar sections and it works perfect,
I just don't understand why it does not work for the Planar Sections....
Remove the last 3 lines, and see what is selected
Tiago Figueiredo
Tooling Engineer
the planar sections are selected
so the selection works fine but the .Name method does not with the planar sections
try this for rename
set NewName=selection1.item(i).value
NewName.Name="MANUAL_ANGULAR_GEOMETRICAL_SET_SECTION_" & i
Tiago Figueiredo
Tooling Engineer
no it does not work either
tells me that NewName does not support the .Name property
