Catia VBA multi-fillet?
DanielMadureira
Automotive
CA
Hi everyone,
First of all, before anyone replies to this message: Thanks eng-tips! I've learned so much just by browsing through the existing forums. So many talented and generous people around here.
Here's what I'm trying to do.
I have a skin in CATIA that is like a saw-tooth kind of thing.
This skin is composed of about 3000 faces, all of them connected.
I'm trying to apply a fillet on all the top intersecting edges of a user value, and a different fillet on the bottom intersecting edges with another user input value.
Radius is the same for all top edges, and the same for all bottom edges.
I can't for the life of me find a VBA or CATScript way of selecting internal edges, putting them into an array and loop through.
I can for example search and select all edges on a solid and apply a fillet or chamfer via VBA.
Is it even possible to select only the internal edges ?
Any ideas?
Thats actually a prettty good idea.
So basically I would create a collection with said surfaces using a loop with a step 2 . Within that loop I could do the fillets, then come back, and with another loop do fillet1 + surface5 - apply second fillet - fillet2 + surface8 and so on.
Then third loop, do fillets with the fillets created, join, save.
Something along these lines? Feel free to suggest another approach, as your scripting knowledge is waaaaaaaay more advanced than mine.
Don't be so sure about my scripting knowledge, I'm not a professional programmer, I just like to learn more about this subject.
For the time being I don't have another idea, I don't know how was created your geometry, another idea would be maybe you can check if some vertex has same coordinates and get their parents and fillet them?
Or if those lower edges are all of them co-planar...find a way to color them and select them in one shot by color....
I suppose in all cases it would be a long run...
Fernando
- Romania
- EU
Here's what i came up with:
Waddaya think?
Code:
Sub CATMain()
CATIA.ActiveDocument.selection.Clear
Dim PartDocumentDest As PartDocument
Set PartDocumentDest = CATIA.ActiveDocument
Dim PartDest As Part
Set PartDest = PartDocumentDest.Part
Dim hybridShapeFactory1 As HybridShapeFactory
Set hybridShapeFactory1 = PartDest.HybridShapeFactory
Set hybridBodies_srf = PartDest.HybridBodies
Set hybridBody_srf = hybridBodies_srf.Add()
hybridBody_srf.Name = "Fillet_Result"
BottomRadius = InputBox("Enter Bottom radius", "Enter radius value in mm", 1)
TopRadius = InputBox("Enter top radius", "Enter radius value in mm", 1)
'Collect Input_1
Dim vntTypes2(0) As Variant
vntTypes2(0) = "BiDim"
Set catSelectLine1 = CATIA.ActiveDocument.selection
    catSelectLine1.Clear
Dim strSelectedItem As String
strSelectedItem = catSelectLine1.SelectElement3(vntTypes2, "Select surfaces.", False, CATMultiSelTriggWhenUserValidatesSelection, False)
'strSelectedItem = catSelectLine1.Search "('Generative Shape Design'.Surface & Color='Dark Green'),scr"
If (strSelectedItem = "Cancel") Then
End
Else
Dim Line_Coll As New Collection
        For sCount = 1 To catSelectLine1.Count
        Line_Coll.Add catSelectLine1.selection.Item(sCount).Value
        Next
End If
'Loop Bottom Fillet:
For iInput = 1 To Line_Coll.Count
Dim ref1 As Object
Set ref1 = catSelectLine1.Item(iInput).Value
Dim ref2 As Object
Set ref2 = catSelectLine1.Item(iInput + 1).Value
Set rf1 = PartDest.CreateReferenceFromObject(ref1)
Set rf2 = PartDest.CreateReferenceFromObject(ref2)
Dim hybridShapeFilletBiTangent1 As HybridShapeFilletBiTangent
Set hybridShapeFilletBiTangent1 = hybridShapeFactory1.AddNewFilletBiTangent(rf1, rf2, BottomRadius, 1, 1, 1, 0)
hybridShapeFactory1.GSMVisibility rf1, 0
hybridShapeFactory1.GSMVisibility rf2, 0
hybridBody_srf.AppendHybridShape hybridShapeFilletBiTangent1
hybridShapeFilletBiTangent1.Name = "Fillet_1"
iInput = iInput + 1
Set rffil = PartDest.CreateReferenceFromObject(hybridShapeFilletBiTangent1)
hybridShapeFactory1.GSMVisibility rffil, 0
Next
PartDest.Update
    Dim catSelectsurf As selection
    Set catSelectsurf = PartDocumentDest.selection
    catSelectsurf.Search "Name=Fillet_1,all"
        Dim FillColl As New Collection
        For sCount2 = 1 To catSelectsurf.Count
        FillColl.Add catSelectsurf.selection.Item(sCount2).Value
        Next
'Invert Surfaces
For iAxis = 1 To FillColl.Count
Set refInv = PartDest.CreateReferenceFromObject(FillColl.Item(iAxis))
Set hybridShapeAxisToAxis1 = hybridShapeFactory1.AddNewInverse(refInv, -1)
hybridBody_srf.AppendHybridShape hybridShapeAxisToAxis1
PartDest.InWorkObject = hybridShapeAxisToAxis1
hybridShapeAxisToAxis1.Name = "Inverse_2"
Next
PartDest.Update
        Dim catSelectsurf2 As selection
        Set catSelectsurf2 = PartDocumentDest.selection
        catSelectsurf2.Search "Name=Inverse_2,all"
        Dim FillColl2 As New Collection
        For sCount3 = 1 To catSelectsurf2.Count
        FillColl2.Add catSelectsurf2.selection.Item(sCount3).Value
        Next
'Loop Top Fillet:
Dim ref3 As Object
Set ref3 = catSelectsurf2.Item(1).Value
On Error Resume Next
For iInput2 = 1 To FillColl2.Count - 1
Dim ref4 As Object
Set ref4 = catSelectsurf2.Item(iInput2 + 1).Value
Set rf3 = PartDest.CreateReferenceFromObject(ref3)
Set rf4 = PartDest.CreateReferenceFromObject(ref4)
Dim hybridShapeFilletBiTangent2 As HybridShapeFilletBiTangent
Set hybridShapeFilletBiTangent2 = hybridShapeFactory1.AddNewFilletBiTangent(rf3, rf4, TopRadius, 1, 1, 1, 0)
hybridShapeFactory1.GSMVisibility rf3, 0
hybridShapeFactory1.GSMVisibility rf4, 0
hybridBody_srf.AppendHybridShape hybridShapeFilletBiTangent2
Set ref3 = hybridShapeFilletBiTangent2
Next
PartDest.Update
End sub
