Catia VBA Macro for Selection from Active or Non Active Document
Automotive
If I have 2 product documents open in current session, How do i select or switch between documents within the VBA?
SelectElement2 is used within active document
SelectElement4 is used within non active document
But In my case, I dont know whether selection will be in active document or non active document.
Thanks in Advance
Use SelectElement4. It allows selecting in non-active document, but can handle a tive document as well.
If I'm wrong then it's not possible to achieve with SelectElement... at all.
You can run a timer and check selection manually on every tick.
Thanks Little,
Yes When I use SelectElement4, It is not allowing me to select in Active Document.
