To avoid the twist between sections, make sure the red arrow is pointing in the same clockwise/counter-clockwise direction for all the sections. Also, use Closing Points to determine the starting point on each section.
For more control, add more Coupling Points.
For the most control, make a Multi-Section Surface first (GSD2 workbench, and then use CloseSurface to convert it into a solid.
