crustaccione
New member
- Feb 15, 2012
- 32
I'm trying to use an image as a material surface, but whenever I try to edit the Properties under Apply Material, there is no 'OK' button. I desperately need to change the Scale U,V and Position U,V of the image because I'm trying to work on this tutorial attached.
Slide A-7 is where I'm having problems. I went to create new materials in the catalog but it still boils down to actually modifying the material properties, which I am unable to do. Hope someone can help me out as this is a really minor and frustrating issue. Thank you!
