Catia V5 R18 appears to be a lemon 1
solid7
V5 R18 SP02 HF9
I have listed no less than 7 issues, in less than a week of using R18, which I will submit as APAR. Is anyone else having issues?
The major things are:
1) Text editor - a hard return exits the editor. (where it did not previously) Workaround - create text in a plain text document, and paste it into the Catia text editor. (PITA)
2) I am not able to assign a hot key for either the "Redo" function, nor the "Change Geometrical Set" function. (where I was previously able)
3) Strange workspace anomalies. Some drawings, when maximized, only display as a sliver on the screen. (about 3" wide, from top to bottom) This happens until reboot, and then begins again after I save and reopen. (until next reboot - on and on it goes...)
We have a list of half dozen annoyances, but I don't really feel like taking the space to list them all. Anyone having problems with R18? Methinks it a turd...
Catia Design|Catia Design News|Catia V5 blog
@prolynx
I noticed some parts made in R17 when opened in R18 change color of axis system and wireframe geometry to black.
My latest woe is that in R18, there appears to be some trouble with Catia being able to manage assembly references. I have several tools that use similar details. Because we use an Enovia type naming/saving convention, I have several details which are re-used throughout different tool numbers. So, the same detail or sub-assembly gets saved under the same name, albeit in a different folder. However, when I pull this into an assembly, some of the details change! If I open the same tool in a clean session, everything is exactly as it should be. At least until the assembly becomes involved.
Example: 7/16 OD bushing morphs into a 5/8 OD bushing on assembly. (yet displays correctly in a new session) The part name in the tree is changed, but the instance name remains as it should - thus providing the proof.
Anyone else? Workaround?
