CATIA V5 Pocket with Scaling down patterns 1
tonychan1488
Automotive
May 30, 2018
3
Hi all,
Is there a way that I can make a pattern with scale down size with every iteration?
Example, I have a long Square beam and I want to make a square cut in every 50 mm and I have to make 50 cuts along the beam.
In the first pocket the cut is 10mm*10mm, then the next cut is scaled down 1% smaller and goes on until the last cut.
Is there a way that I can sketch this pattern in one go without sketching the cuts one by one? Thanks!
@Little Cthulhu
Thanks. Where can i find those two options?
