Gurucharanhcl
Aerospace
- Jul 28, 2011
- 10
Hello All,
In the below attached script, text size greater than 7 mm will selected in catia v5 drawing and changed to red color.
In the same context if I want to select text size which are equal to 0.156 inch then how should it be incorporated in the script. I think by default script is considering millimeter units and I need to specify the length in inches without converting 0.156 inches to millimeter.
Thanks in advance,
Guru Charan T
Thanks in advance,
Guru Charan T
