CATIA V5 Macro Text Properties
anthony71
New member
IT
I'm trying to make a Macro for Drawing Title Block.
I can't applied the following proprieties to my new text (will be the drawing number):
Flip Mode (Horizontal);
Orientation (Vertical).
For the Flip Mode I've tried with this input in the Script:
Dim Tex1Prop As Drawing TextProperties
Set Tex1Prop = MySheetNum.TextProperties
Tex1Prop.Mirroring = catTexHorizontalFlip
But it doen't work..
For text Orientation I have no ideas..
Someone could kindly help me?
thanks a lot..
thanks a lot drewmumaw!!..it works now...the error was "Mirroring" the right is "Mirror" ...
Do you know the right input for text orientation?
you can rotate text like this
Code:
 'CreateTextAF (Text_04,GetOH()+Col(1)-160  ,GetOV() + Row(4)+63 ,"TitleBlock_Text_EnoviaV5_Effectivity" ,catMiddleCenter,3.5 &t).Angle=90
Thanks a lot to everybody!!...Now the Script works properly!!...
