Catia V5 - Image Quality
LuisAzevedo
Industrial
PT
I'm using Catia V5, and I need to save four objects, each one with diferent heights.
I've saved using Image->Capture->Pixel Mode, and save jpeg high quality. I've tried another formats but the result is always the same: image is pixelated.
What process should I use to have image with good quality, as I see in the stage?
Thanks in advance!
Luís
set rendering quality to highest and semantic level to discretized. let us know if it helps
Thank you very much for your answers!
I played with the setting but with no results, even the semantic level to discretized.
Another process that I tried was the Photo Studio. The quality is very good...I will see if I can work with that.
Thanks!
Luís
if you need pictures for a huge poster then capture tool not good for that. for a a4 or even a3 presentation it's pretty good.
