Catia v5 change mouse cursor size 1
Velvetk
IT
Hello
I got a little problem with mouse cursor size, when i had to select small objects like points ect. ect.(the hand with pointing finger),because it's too small it become difficult to select those objects rapidly. Even when I press ALT + left mouse button (the object I try to select will not be listed, atleast at the first try) There is any possibility to increase the size of the cursors?
Tanks anyway
You can try changing the Pick Window size to have the cursor look at a larger/smaller area. (I didn't have much success with this, so I went back to a size of 4. Maybe you'll have better luck with it?) Tools + Options - General + Display + Performance.
Another suggestion: Usethe User Selection Filter to only select points.
(why is it so difficult to add pictures here?)
Hi!
Tanks for the time spent.
I solved my issue using your suggest (selecting 10 for window size) in addition i also activated the accurate picking check mark and changed the value to 3.
Now it works fine even when I use the ALT+left mouse button for picking list.
