CATIA v5 CATScript Macros
Sid Pattisapu
Hello, I am fairly new to CATIA v5 Macros. I'm fairly new to Macros in CATIA v5. I'm having trouble Isolating a sketch in CATIA using Macros. Similarly with changing the sketch support. Is there a quick way that I can do both of them?
This is my code
Sub CATMain()
Dim partDocument1 As Document
Set partDocument1 = CATIA.ActiveDocument
Dim part1 As Part
Set part1 = partDocument1.Part
'-----------------------------Extraction and sketch operation--------------------
Dim sel As Selection
Set sel = partDocument1.Selection
sel.clear
sel.search("..Name='Step.3',All")
Dim extract1 As HybridShapeExtract
Set extract1 = sel.item(1).value
part1.UpdateObject extract1
sel.clear
sel.search("..Name='Step.4',All")
Dim plane1 as AnyObject
Set plane1 = sel.item(1).value
part1.UpdateObject plane1
sel.clear
Dim hybridShapeFactory1 As Factory
Set hybridShapeFactory1 = part1.HybridShapeFactory
Dim origin As HybridShapePointOnCurve
Set origin = hybridShapeFactory1.AddNewPointOnCurveFromPercent(extract1, 0, False)
origin.Name = "Point.origin"
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim hybridBody1 As HybridBody
Set hybridBody1 = hybridBodies1.Add()
hybridBody1.Name = "Point"
hybridBody1.AppendHybridShape origin
part1.Updateobject origin
Dim endpt As HybridShapePointOnCurve
Set endpt = hybridShapeFactory1.AddNewPointOnCurveFromPercent(extract1, 1, False)
endpt.Name = "Point.end"
hybridBody1.AppendHybridShape endpt
part1.Updateobject endpt
Dim hax As HybridShapeLinePtPt
Dim Ref1,Ref2 As AnyObject
'Set Ref1 = part1.CreateReferenceFromObject(origin)
'Set Ref2 = part1.CreateReferenceFromObject(endpt)
Set hax = hybridShapeFactory1.AddNewLinePtPt(origin,endpt)
hax.Name = "haxis direction"
hybridBody1.AppendHybridShape hax
part1.Updateobject hax
Dim haxis(2)
hax.GetDirection haxis
sel.Search("..Name='Step.5',All")
Dim sketch1 As Sketch
Set sketch1 = sel.item(1).value
Dim Coord(2)
origin.GetCoordinates Coord
Dim absdata(8)
sketch1.GetAbsoluteAxisData absdata
absdata(0) = Coord(0)
absdata(1) = Coord(1)
absdata(2) = Coord(2)
absdata(3) = haxis(0)
absdata(4) = haxis(1)
absdata(5) = haxis(2)
sketch1.SetAbsoluteAxisData(absdata)
sel.clear
sel.Add sketch1
CATIA.StartCommand "Isolate"
part1.UpdateObject sketch1
sel.clear
'part1.IsolateObject sketch1
'part1.update
End Sub
The SetAbosulteAxisData command sets the sketch where i want it to be but doesnt update the geometric support. Also, the Isolate command doesnt seem to be doing anything
