CATIA.StartCommand ("Center Graph") Problem
Catiaer
KR
Hello all,
Here is an example of CATIA.Startcommand that I found on the internet.
I tested in the part design workbench then it sometimes(?) works.
I mean that after I reopen a catia instance, it works.
But when I use it 2 or more, it doesn't work any more..
And in assembly work bench I could have never seen that it works.
I tried to use with sendkeys that I type "Center Graph" as command and press enter key.
Before I did it, I tested manually to type "Center Graph" and entered, it didn't work also.
But when I use center graph in the command list, it works gut very well in the both workbench.
And the other function seems to work well, ex) reframe on, hide and show, etc
Is there another way to use center graph?
Code:
Sub CATMain()
Dim oSel As Selection
Set oSel = CATIA.ActiveDocument.Selection
Dim Name As String
Name = InputBox("Please enter name of geometry to search for.")
'In next line selection will search for name from inputbox  inside all parts or products.
oSel.Search ("Name=" & Name & "*,all")
'When we made selection now we can use it
iCount = oSel.Count
MsgBox ("Number of shapes found: " & iCount)
For I = 1 To iCount
'    CATIA.StartCommand ("Collapse All")
'    CATIA.StartCommand "Center Graph"
Next
End Sub
'You can run this macro in part and product!!
of course, before I post here, I tried to search it in google first, and here also.
And I tried to all code with startcommand "center graph", but there is no good result.
And? You didn't notice that your command is not focusing on anything?
You need first to select something and then go with your command. Inside your loop, you don't have any selection. Please check again those posts to understand how this type of command is working.
Fernando
I understand that loop, but only that center graph doesn't work, when I change it to fit all in or hide and show command, then it works. That is what I didn't understand.
Maybe this will guide you more, input the exact name just to show that the command is working. It will work in the same way in a loop.
Sub CATMain()
oSel.Clear
Dim Name As String
Name = InputBox("Please enter exact name of geometry to search for.")
oSel.Search ("Name_CAP=" & Name & ",all")
End Sub
Fernando
Catiaer (Mechanical)(OP) is right.
"c:Center graph" works only if the active workbench is not assembly design.
Solved it !
You have to assign an user alias to this command and use that name in place of "center graph".
Works every time.
Use command header id instead:
Code:
CATIA.StartCommand "CATCafCenterGraphHdr"
@Little Cthulhu (Marine/Ocean)
Thank you. Where can i find a list of header id commands ?
