CATIA MACRO TO CREATE EACH BODY AS A PART 1
bratosinmihai
Computer
IT
Hi everybody,
I found a macro which generate each body from one catpart in separate catpart inside new product , 1 body= 1 catpart
I tried to modify this vbscript for what I need but doesn t work
I want to select bodies which I need with "tools pallete", no all bodies from catpart ( see photo 1) and then
I need to copy them and paste in product selected by me,existent one, no a new product, (see photo 2)
Is there someone to help me to resolve this problem???
Language = "VBSCRIPT"
Dim KomponenteNeu As products
Dim KoerperName
Dim OpenKoerperName
Dim hybridBodies As document
Dim Koerper As Object
Dim QuellFenster As Window
Dim Letztekoerper
Dim UserSel As Selection
Sub CATMain()
Dim Activdocu As document
Set Activdocu = CATIA.ActiveDocument
' Neue Product
Dim PosString As Long
partName = CATIA.ActiveDocument.Name
Dim docu As Documents
Set docu = CATIA.Documents
Dim productDocu As document
Set productDocu = docu.Add("Product")
Dim ProductNeu As Product
Set ProductNeu = productDocu.Product
PosString = InStr(1, partName, ".CATPart")
ProductNeu.PartNumber = Mid(partName, 1, PosString - 1)
FensterNebeneinander
Set QuellFenster = CATIA.Windows.Item(1)
QuellFenster.Activate
Dim partBodies As Bodies
'Set Activdocu = CATIA.ActiveDocument
Set partBodies = Activdocu.Part.Bodies
Dim koerperAnzahl
koerperAnzahl = partBodies.Count
Dim UserSel As Object
For I = 1 To koerperAnzahl
Set Koerper = partBodies.Item(I)
KoerperName = Koerper.Name
If Right(KoerperName, 1) = "\" Then
KoerperName = Left(KoerperName, Len(KoerperName) - 1)
End If
KoerperName = Replace(KoerperName, "\", "_")
'Koerper kopieren
Activdocu.Selection.Clear
Activdocu.Selection.Add Koerper
Activdocu.Selection.Copy
'Part erzeugen und Koerper einfuegen
Dim PartNeu As Product
Set PartNeu = ProductNeu.products.AddNewComponent("Part", CStr(KoerperName))
' Fenster mit neue Product activieren
ProductNeu.parent.Activate
' Alle Parts suchen
PartSuchen ProductNeu.parent, UserSel
'ProductNeu.parent.Selection.Clear
'ProductNeu.parent.Selection.Add UserSel.Item(UserSel.Count).Value
ProductNeu.Parent.Selection.Clear
ProductNeu.Parent.Selection.Add ProductNeu.products.Item(PartNeu).ReferenceProduct.Parent.Part
ProductNeu.parent.Selection.PasteSpecial "CATPrtResult"
Next
Dim hybridBodies As hybridBodies
Set hybridBodies = Activdocu.Part.hybridBodies
koerperAnzahl = hybridBodies.Count
Set Koerper = hybridBodies.Item(I)
End If
'Koerper kopieren
' Alle Parts suchen
Next
' Product actualisieren
ProductNeu.ApplyWorkMode DESIGN_MODE
On Error Resume Next
ProductNeu.Update
If Err <> 0 Then
MsgBox "Problem with update!" & vbLf & vbLf & "Please update manual!", vbCritical + vbOKOnly, "Update-Error"
End If
On Error GoTo 0
End Sub
Sub PartSuchen(oPartDoc1, UserSel)
Dim E As Object 'CATBSTR
Dim Was(0)
Was(0) = "Part"
'Dim UserSel As Object
Set UserSel = oPartDoc1.Selection
UserSel.Clear
'Let us first fill the CSO with all the objects of the model
UserSel.Search ("CATPrtSearch.PartFeature,all")
'E = UserSel.SelectElement2(Was, "Alle CATPart wählen", True)
'Letztekoerper = UserSel.Count
End Sub
Sub FensterNebeneinander()
Dim windows1 As Windows
Set windows1 = CATIA.Windows
windows1.Arrange catArrangeTiledVertical
End Sub
1.To run only on your selection, create a new collection, add all bodies from your selection and modify the script to run only inside your collection (not on all bodies).
something like this:
Dim myBodies as Collection
Set myBodies = new Collection
for i=1 to myPartDocument.Selection.Count
myBodies.add myPartDocument.Selection.Item(i).Value​
next
'then parse this collection
myPartDocument.Selection.Clear
for each myBody in myBodies
'copy-paste, bla bla bla​
next
2.For the other question, there are many options: use SelectElement4 method or use an inputbox for the user with all ProductDocuments opened in your session, or just hard code it.
Now, I hope it helps although I suspect you are not familiar with scripting in V5 at all.
Calin
Thanks for answer. Yes I am not familiar with vbscript but I am reading about it for two weeks.
