Catia macro to automate drawing sheet numbers
JANE15
Aerospace
SG
I'm trying to write a macro which automates the sheet numbers on my drawings. For example sheet 2 of 3.
I have found a code which works to print this information in the sheet background although I cannot find a way to update these numbers if a sheet is later added or deleted. At the moment if I run the macro again it simply prints the new numbers on top of the previous (so you can see both).
I'm trying to find a way that the existing text box can be either updated or deleted by the macro when an update is needed.
Hope this makes sense! Any help would be greatly appreciated.
Just an idea: first time when you create the textbox, name it specifically. Thus, when running the script again, you can address it directly from the collection of Texts of your Background View.
First, count the number of sheets of your file,
then go to each sheet, and add the number.
try this:
Code:
Dim MyDoc As Document
Dim MyDrawingDoc As DrawingDocument
Set MyDrawingDoc = CATIA.ActiveDocument
Dim DrwDocument   As DrawingDocument
Dim DrwSheets     As drawingSheets
Dim DrwSheet      As drawingSheet
Dim DrwView       As DrawingView
Dim DrwTexts      As DrawingTexts
Dim Text          As DrawingText
Dim Fact          As Factory2D
Dim Point         As Point2D
Dim Line          As Line2D
Dim Cicle         As Circle2D
Dim Selection     As Selection
Dim GeomElems     As GeometricElements
For Each DrwSheet In MyDrawingDoc.Sheets
Dim sheet As Integer
Dim sheet_count As Integer
sheet = sheet + 1
sheet_count = MyDrawingDoc.Sheets.Count
'Insert sheet number
Set MyText1 = MyDrawingViews.ActiveView.Texts.Add(("Sheet " & sheet & " / " & sheet_count), 100, 14.5)
MyText1.WrappingWidth = 23
MyText1.SetFontSize 0, 0, 1.8
next
Tiago Figueiredo
Tooling Engineer
Youtube channel:
