Catia Macro : Measurable.GetPoint() not able to get XYZ Co-ordinates
jagandeep
Automotive
May 27, 2013
82
Hello Friends
Measurable.GetPoint() is not giving me the co-ordinates in most of the cases. I have tested the code on many computers with different catia versions. In most of the cases it fails to report the co-ordinates(On One PC it does works).
But to my surprise if I create out-Process macro out of same code It works without any problem. I am not able to find root cause of the solution
Below is my VBA code
Code:
Option Explicit
Sub CatMain()
    Dim MyDoc 'As Document
    Set MyDoc = CATIA.ActiveDocument
    If Not (TypeName(MyDoc) = "PartDocument") Then
        MsgBox "This Command Works only on Part Documants", vbCritical, "Error"
        End
    End If
    Dim MySelection 'As Selection
    Set MySelection = MyDoc.Selection
    Dim Status As String
    Dim vFilter(0)
    vFilter(0) = "HybridBody"
    MySelection.Clear
    Status = MySelection.SelectElement2(vFilter, "Select Geometric Set Containing 3D Points", True)
    If Status = "Cancel" Then
        End
    End If
    Dim MyHybridBody 'As HybridBody
    Set MyHybridBody = MySelection.Item(1).Value
    If MyHybridBody.HybridShapes.Count = 0 Then
        MsgBox "Geometric Set is Empty", vbCritical, "Error"
        End
    End If
    Dim TheSPAWorkbench 'As SPAWorkbench
    Set TheSPAWorkbench = MyDoc.GetWorkbench("SPAWorkbench")
    Dim MyPoint 'As Point
    Dim Reference1 'As Reference
    Dim TheMeasurable 'As Measurable
    Dim coords(2)
    Dim i As Integer
    On Error Resume Next
    For i = 1 To MyHybridBody.HybridShapes.Count
        Set MyPoint = MyHybridBody.HybridShapes.Item(i)
        Set Reference1 = MyDoc.Part.CreateReferenceFromObject(MyPoint)
        Set TheMeasurable = TheSPAWorkbench.GetMeasurable(Reference1)
        TheMeasurable.GetPoint (coords)
        If Err.Number = 0 Then
            Debug.Print (coords(0)) + ", " + CStr(coords(1)) + ", " + CStr(coords(2))
        Else
            Debug.Print "Error in Getting XYZ from " + MyHybridBody.HybridShapes.Item(i).Name
            Err.Clear
        End If
    Next
End Sub
Below is the output of sample run
Code:
Error in Getting XYZ from Line.1
Error in Getting XYZ from Plane.1
Can Anyone help me out !
Ferdo
Geometric set also contains 3d points. The macro returns empty values as shown in output with spaces and commas for same.
I am not concerned about anything other then points. That was just sample output.
I saw, because I was interested in the past to get such kind of info here is a part of my code (you need to handle the problem of not showing other elements in Geo Set). Code is working also inside a CATProduct
Code:
Sub CatMain()
    Dim docPart         As Document
    Dim myPart          As Part
    Dim hybBodies       As HybridBodies
    Dim hybBody         As HybridBody
    Dim hybShapes       As HybridShapes
    Dim hybShape        As HybridShape
    Dim arrXYZ(2)
     Dim s               As Long
    Const Separator As String = ";"
    Set docPart = CATIA.ActiveDocument
    'If no doc active
    If Err.number <> 0 Then
        MsgBox "No Active Document", vbCritical
        Exit Sub
    End If
Dim was(0)
Set userSel = CATIA.ActiveDocument.Selection
was(0) = "HybridBody"
userSel.Clear
aText = userSel.SelectElement2(was, "Select Geometrical Set", True)
Set hybBody = userSel.Item(1).Value
Set hybShapes = hybBody.HybridShapes
    ' Search HybridShapes (Point 3D)
    For s = 1 To hybShapes.Count
                Set hybShape = hybShapes.Item(s)
                    'Extract  coord
                    hybShape.GetCoordinates arrXYZ
                    MsgBox ((hybShapes.Parent.Name) & Separator & (hybShape.Name) & Separator & _
                                  arrXYZ(0) & Separator & _
                                  arrXYZ(1) & Separator & _
                                  arrXYZ(2) & vbLf)
     Next s
End Sub
Fernando
Thanks Dear
The above code is working for me. However I am yet to understand what is problem with measurable.getpoint
if you check FAQ you find my script to get xyz to text file.
the solution is
TheMeasurable.GetPoint coords
not
Eric N.
My Bad
The silly mistake done by me
Thanks Itsmyjob for pointing it out.
