CATIA Macro: algorithm 1
elmundo777
Automotive
BY
Hello. I need help with creating algorithm.
I'm trying to assign names to CATIA tree elements from table rows. See pictures:
Tree:
Table:
I have an idea how it should look roughly in pseudocode, but I don't have enough knowledge to implement it. (vb.net language or catscript\c#\vba. does not matter).
Cycles in pseudocode:
For i = 1 to catia.docs.count
For Z = 0 To DataGridview.Rows.Count - 2
Dim nameRename As String = DataGridview.Rows(Z).Cells(0).Value
item(i).name = nameRename
How to implement it correctly?
Thanks!
File names, instance names and partnumbers are all independent in CATIA.
Moreover, the idea of renaming specification TREE based on excel TABLE data seems like a bad one. It will lead to errors and ambigious results in models with more than one level of indentation.
Why would you want to do what you're describing in the first place? What is your final goal?
I want to create a small but useful utility for quick renaming.
And then saving to the selected directory
Why would you need a tool like that? There's a "Save management" command.
What about instance namea and partnumbers? Are you going to provide them as an input as well?
For the instance name, the name is also changed in the cycle. instance name = part number + .1
there are no problems with these.
the problem is to assign names to the documents one by one as they are given in the table.
Second problem - if the root product does not exist on disk and I try to save it with a new name - I get an error 0x8004005
So I want to change all the names that I require
and then save it as the whole product.
save management doesn't suit me.
I have name templates written to the table. which greatly simplifies the process.
This is good video. But it didn't make it any easier. it won't solve my problem
Code:
Selection.Search "CATAsmSearch.Product+CATAsmSearch.Part,all"
for i=1 to Selection.Count
  Selection.Item(i).ReferenceProduct.Parent.SaveAs   ExcelRange(i)
Next
Good decision. But I can't beat the problem of renaming a not yet saved main product.
I always get an error.
Next
Also i have this:
Item(i).Value.ReferenceProduct
As for saving not yet saved product try calling Save before SaveAs
I don't know what i do wrong....
I found one of the errors: the saved files have a link/reference to the old files and display their data, not the new ones.
how to make an analogue using code? (see picture below)
Try inverting for loop order
I had an idea to run in reverse order
but nothing is saved
i'm get an error
Code:
 oSelection.Search("CATAsmSearch.Product+CATAsmSearch.Part,all")
        for i =  oSelection.Count to 0 step -1
            ' oSelection.Item(i).Value.ReferenceProduct.Parent.Save()
            oSelection.Item(i).Value.ReferenceProduct.Parent.SaveAs(pathQ & "\\" & documents1.Item(i).Name) 'HERE AN ERROR System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component.
        Next
Inspect what value you actually use as save path and try saving using exactly that value manually. We're talking about last (first in a loop) document.
By the way loop should end with 1, not 0
in any case, links to previous versions remain.
eg: I created a product document. added 3 products and one part to it. gave names.
product 1e
--product 2e
--product 3e
--product 4e
--part1e
saved them to next folder: c: / temp / 1 /
then I rename this document as follows:
product 1__a
--product 2__a
--product 3__a
--product 4__a
--part1__a
save to folder
c: / temp / 2 /
as a result, the names from folder 1 are saved, but the names are new in the tree structure itself.
I assume this is due to links and needs to be saved as a new document. but how to do that?
Next
Could you also suggest how to save only the selected components?
analog save management
Try using SendTo for saving. If it won't work you have to use NewFrom and make document "copies" by yourself.
