CATIA knowledge advisor
TiagoFigueiredo
Industrial
May 22, 2013
503
I everyone,
I'm trying to create a rule, to change the anchor point, controlled by a parameter, with knowledge advisor.
Anyone knows how to do it?
i'm new to knowledge advisor, where I can find the help or a guide?
Tiago Figueiredo
Tooling Engineer
That works in a macro, but I want to make a rule in Knowledge.
Tiago Figueiredo
Tooling Engineer
Pull up the Formula Editor, then select an existing hole that has been configured with the preferred settings. There is a high probability there is a Parameter that will control that behavior that you could utilize with KW functionality.
--Doug
dougsnell
that property is no available. I solved already the problem, with a reaction linked to a "VBScript with argument" feature .
Tiago Figueiredo
Tooling Engineer
