You're absolutely right IRStuff. However, it is a cheap enough reference that will at least give him some basics on fluid flow that might get him closer to the ball park. I don't have time to read attachments such as his code, and was just picking up on the comments about using the ideal gas law to model a liquid such as water or saline.
Since we don't know if the cathetar is going to be placed inside the body and we also don't know the properties of the "balloon" fabric -- which really does play a role -- there's only so much that can be done. We can't really teach sph99 fluid flow over these forums -- and to be honest, he couldn't teach me (at least) structural engineering either. The book will give him a practical starting point. Between that, his test data, and his coworkers, hopefully it will be enough to solve his problem. If not, well, then the usual advice is to hire the right expertise, isn't it?
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
