Catenary 2
Danilo917
47
Hi Engineers,
any suggestion on what formula to use to create a catenary given the sag and span of conductors?
Cheers!
See thread238-8018
Alan
“The engineer's first problem in any design situation is to discover what the problem really is.” Unk.
Thanks for your replies..I find it really so useful..ill ask more question about your posts in a short while..thanks again.
Hi Engineers,
Another question/request,i wonder if the simple catenary can be designed using MSExcel given the sag and span for level and un-level condition?
thanks
I'm sure it can. You need to account for the physical properties of the particular conductor material, such as stress/strain characteristics, thermal expansion and creep.
This is an excellent reference.
If you are designing a line, you would probably be better to hire someone with experience in this area, as there is a lot to know.
Alan
You can use Excel for simple catenaries without stress/strain characteristics, thermal expansion, and creep if you are only interested in one loading/temperature condition.
You need these conductor characteristics if you need to find the sag-tension at a different loading/temperature condition. For instance, you might want to calculate the stringing sag and tension at 60°F to get a sag at 120° final with wind. For this, an Excel spreadsheet may not be feasible because the calcuations are pretty complex, especially for a composite conductor like ACSR.
If your time is worth anything, it might be more economical to buy something like this:
Alan
