steelmtllrgst
Materials
I have a piece of equipment that I put on embedded rails (~30ft of rail) that requires a 120V feed and two ethernet cables to operate.
I want to run the ethernet and power through a reel to keep them from getting tangled, run over by fork truck ,etc. I want to run the cables together on the same reel, but I was told that the 120V line will interfere with shielded ethernet if they are not separated.
Should interference be a concern? It chance of data corruption dependent on amount of data (very little in this case)? Any suggestions?
