I tried to predict RVP, RON and P/N/A of heavy and light platformate with Hysys using ASTM distillation and density @ 15C, but got pretty bad results, i.e. bad match with experimental data.
What I did:
took PR from fluid packages, entered oil environment, defined my steam by its standard density in bulk properties and entered ASTM D 86 data, picked auto calculate for light ends,calculated assay, installed oil as blend, defined the stream in simulation environment, and got cold properties form tools menu.
In case of light platformate, I got the folowing deltas:
RVP: 30%
RON: 11%
P: 73%
N: 850%
A: 73%
and I am not very happy with them.
I outlined above what I did in case I made some procedural mistake. If I did, somebody please point out. If not, can somebody advise how to obtain better results, if that's at all posible.
Also, if Hysys is inadequate for this, please advise on more appropriate method.
Best Regards,
B.Radovanovic
What I did:
RVP: 30%
RON: 11%
P: 73%
N: 850%
A: 73%
Best Regards,
B.Radovanovic
