Hi, I just had my Honda Accord aligned and i just want to double check if it is of any concern that there is some slight variations to the factory spec after alignment. I cant really find anyone with suitable knowledge on this on the regular car forums i frequent.
The measurements I'm concerned with are:
At rear:
Setback: initial reading = -8.5mm, final reading = -13.6 mm
Is this acceptable/normal that the magnitude actually increased during the alignment? Is this value also acceptable in general?
At front:
Caster initial left +2.24, initial right +2.58 , final reading left = +1.81, right = +2.62. In the service manual it calls for minimum 2.5 castor (target is +3.5) as well as no greater than 0.45deg difference between both sides, which I am not complying with now.
Is this a concern to go back to the shop?
MY SAI(given as kingpin) angle also wasnt adjusted ...at initial reading, one side was 6deg, the other was 2.85 , and target was 8.58 for both sides, but no final value was given at all. Is this angle even adjustable?
I am greatly appreciative for any insight into this. I can't thank you enough for any guidance.
regards,
Mike
At rear:
At front:
regards,
Mike
