Cast to AxisSystem not working 1
solid7
This was a super quick script, scrambled together to unit test a larger bit of functionality.
I think it's pretty straightforward, and there's a relevant comment. So help me understand why this doesn't work. I cast selections to object types all over the place, in all kinds of code. This PARTICULAR case is nagging me hard.
Code:
public void Macro_FindPartParent()
     MessageBox.Show("This function will find the Parent Object.");
     Editor cEditor = CATIA.Editors.Application.ActiveEditor;
     Selection cSelection = cEditor.Selection;
     MessageBox.Show(Information.TypeName(cSelection.Item2(1).Value));
     var e = Information.TypeName(cSelection.Item2(1).Value);
     if (e == "AxisSystem")
          MessageBox.Show("This is an AxisSystem");
          // BOOM!!!
          AxisSystem cAxisSystem = (AxisSystem)cSelection.Item2(1);
          MessageBox.Show("" + cAxisSystem.get_Name());
     else
          MessageBox.Show("Not an AxisSystem");
cSelection.Item2(1) has type SelectedElement
Correct way to address actual selected object:
(AxisSystem)cSelection.Item2(1).Value
Yep, it sure is.
Can you also explain, why .Parent property doesn't work? (even after returning this as a properly cast object)
In .NET Parent property should be invoked on actual object interface, not just INFITF.AnyObject which is a base for (almost) all interfaces.
For instance, both of these lines will compile but it's the second one that actually returns correct interface:
Code:
PartDocument doc;
doc = ((INFITF.AnyObject)partRoot).Parent;
doc = ((MECMOD.Part)partRoot).Parent;
To be completely clear, Parent there are cases when Parent do work with AnyObject, but I find it more reliable to perform direct cast to a well-known interface and then invoke Parent (as above).
Ah, that makes sense. Thanks.
