I am putting together a specification for a project and am not quite clear on specifications used in the 1960s. I am tying 3" DI pipe into existing Cast Iron piping using modern DI fittings. I have the old specification that these pipes were built to and it calls out cast iron piping, specifically "USAS 21.6 or 21.8, Class 22 mechanical joint to USAS 21.11 cement mortar lined to USAS 21.4, bituminous coating".
My question boils down to the class 22 nomenclature, I suspect that USAS evolved into ANSI/AWWA since the numbers line up. I do not have a copy of any of these specifications handy, but is "Class 22" called out in one of them? I've got information on thickness class 5x and pressure class XXX pipe, but nothing about class 22. I ask because I want to tie in the new DI stuff using all pressure class 350 stuff, and I want to say that pressure class 350 meets or exceeds class 22 Cast Iron.
