ae11
- Apr 1, 2008
- 3
In a single-family residential project, we're considering use of a cast in place concrete wall system where there are a couple of inches of rigid insulation embedded in the center of the wall forms. In effect, if we had a 8" total wall thickness, we'd have let's say 3" concrete face, then 2" rigid insulation, then another 3" concrete face.
Questions:
(1) general thoughts or experience with this system
(2) any way to get the system to behave more like an 8" solid wall, instead of two 3" concrete faces? The hope is that this system might be able to carry vertical loads from above.
(3) how to accommodate concentrated loads at the top of this wall, like where a concrete beam is supported at the top of the wall. One option might be to not use insulation immediately below the concentrated load, using 8" solid concrete all the way to the ground (could be a couple of feet in width). Another thought is to fill in a solid area immediately below the concentrated load, like how you might grout solid a few cells in masonry immediately around a concentrated load, but the solid area doesn't extend all the way to the ground).
(4) on a related question, how thin are people typically comfortable with for a solid concrete wall (ignoring the internal insulation question) for 2-story residential construction? Assume I have a better-than-average concrete contractor. Also assume I want to bear concentrated loads from concrete beams on top of the wall.
(5) how skinny/practical can I make a concrete column, assuming it's lightly loaded, not exceptionally slender, etc...8"x12"?? Of course I know it depends on the loads and slenderness ratio, but I guess I'm trying to determine what the practical limit might be for good quality residential construction.
Keeping my fingers crossed for not overly conservative feedback
Questions:
