cass test/ with stainless steel? 1
nicksertic
1
Is there any literature or test results on cass tests with 301 stainless steel without any plating?
Why would it have been done on stainless, since the spec doesn't address that?
1.2 This method is applicable to evaluating the corrosive performance of decorative copper/nickel/chromium or nickel/chromium coatings on steel, zinc alloys, aluminum alloys, and plastics designed for severe service. It is also applicable to the testing of anodized aluminum. The suitability of this test and correlation of results with service experience should be determined before it is specified for coating systems or materials other than those mentioned in this paragraph.
Corrosion, every where, all the time.
Manage it or it will manage you.
I was wondering the same thing...
