fastline12
Aerospace
We are looking to build a variable speed, constant pressure water well system for use in a geothermal grid. We would like to use a 1.0-1.5HP system to flow between 10-21GPM. This pump would also provide drinking water.
I have contact OEMs regarding pump efficiency other than 60hz synchronous operation but not much info. I would really like to know if a pump that is optimized for max eff at 33GPM, what would the eff look like at half speed? These would be multi stage cased well 4" pumps. I would like to take advantage of the service factor in a 1HP pump and overspeed the pump slightly so we can get the best possible performance at the mostly required 10-15GPM.
