Case Statement
Phrodeaux
Currently, having problems with a case statement. Case 265 and Case 229 are not sending out the correct values. Do I need a Case to statement to correct this? Any and all help will be appreciated.
Sub LandDrill(ToolDiameter, Flutes, TolPlus, TolMinus, FluteStyle)
Select Case FluteStyle
Case 204
Select Case ToolDiameter
Case Is < 0.2499
TolPlus = 0.5 * ToolDiameter
TolMinus = 0.6 * ToolDiameter
Case Else
TolPlus = 0.55 * ToolDiameter
End Select
Case 212
Case Is < 0.2499
Case Else
End Select
Case 265
TolPlus = 0.66 * ToolDiameter
TolMinus = 0.74 * ToolDiameter
Case 229
TolPlus = 0.15 * ToolDiameter
TolMinus = 0.2 * ToolDiameter
Case Else
End Select
End Sub
What happens if you move those case statements up to the top of the function?
No luck on moving the 229 and 265 statement to the top. Pulls hair out
When you feed in 229 or 265, which section of code appears to be executed?
Perhaps you should ensure that the FluteStyle argument is either of type Integer or of type Long.
Is FluteStyle an integer? Is it part of an enumeration? Are you sure the value of 229 or 265 is being passed into the Sub? Can any other procedure change the value of FluteStyle (or any other variable used in LandDrill) before calling Sub LandDrill (I notice it is passed by ref - the default if not specified by val).
Two things I would try: put the case numbers in ascending order and eliminate the nested select case statements. I can't guarantee this will help, it's just what I'd try.
Code:
        Case 204
            If ToolDiameter < 0.2499
            Else
            End If
        Case 212
            Else
            End If
        Case 229
        Case 265
        Case Else
        End Select
End Sub
It may depend on which version of Excel you're using. I seem to recall that some older versions require that Select Case statements with numeric arguments need to be in numeric order, although that isn't the case now (XP)
Good Luck
johnwm
________________________________________________________
To get the best from these forums read faq731-376 before posting
UK steam enthusiasts:
I'd feed it a value, then step through the function in VB, looking at values. Does it work in the VB editor environment but not the spreadsheet?
