Most cartridge cases used by the US militarey today are made from brass, with some medium calibers (25mm, 30mm) using aluminum. Russia and most of the former East Bloc nations use steel. Steel would probably be a bit cheaper than brass, but is more susceptible to corrosion.
Since steel seems to work well for the Russians in terms of cost and performance, why hasn't more use of this material been made in the US for ammo casings? Is it too hard on the internal mechanisms of weapons? Also, I don't think it lends itself to reloading.
