I'm new to the board and would like some informed guidance in selection of tires from folks who design them (and/or cars) for a living. The people at the retail/sales/customer service level just don't get it, especially when I'm deviating from the car's perceived expected usage...
First some background... the car is a 2005 GTO that is a daily driver, usage is 80+% interstate commuting, and typically driven lightly (cruise engaged) to moderately (weekend trips on two-lane rural roads where lateral forces might approach 0.7g). It's never been slid through a corner, drag raced, driven at sustained triple digit speeds or otherwise abused. Came from the factory with BFG KDWS 245/45-17 95W tires (it’s governed @ 158). A very good choice by GM in my opinion, as these tires offer excellent dry and wet grip and acceptable levels of ride quality and noise generation. Given the 400 treadwear rating, wear has been disappointing as I'm @ 20K miles and by 24k will be down to the wear bars (rotations every 5K, alignment optimal per factory specs).
So now my dilemma... I need to go from "acceptable" ride quality and noise control to "excellent" or "exceptional" without giving up dry or wet braking capacity. The car's suspension system is tuned appropriately... offers an excellent blend of comfort and control/feel. But the tires have always had a harshness to them (or, lack of sophistication) I find that detracts from the driving experience. Don't know if I'm getting too old or what, but NVH control is a major thing with me anymore. Given all of this, I've decided to change tire segments and drop speed ratings.
Based on my experience with these installed on my minivan (225/60-16 98H) I'm going with the Continental ContiProContact. On the Odyssey they are an excellent fitment... Same if not better NVH characteristics as the Michelin MXV4 Plus they replaced but with much better wet traction, equivalent steering response, and less expensive. They do seem to be wearing a bit faster than the Michelins did, so from a cost/mile perspective it might be a wash. So here is my primary question: do I go with a 99H or a 99V on the GTO?
My current tire (the BFG) has the following construction: 2 polyester carcass plies, tread 2 steel + 1 nylon.
The ProContact on the van has 1 poly carcass ply, tread 2 steel + 2 nylon. Right away I realized that going from a multi-ply carcass to a mono-ply probably explained the segment difference (UHPAS vs. GTAS)...
I checked out an Audi A6 where the 245/45-17 99H ProContact is OE and found the following: 1 rayon carcass ply, tread 2 steel + 2 nylon. According to Conti the OE 99H and replacement market tire are one and the same. The 99V is a new product for them (there's also a new 95H runflat in the same size I'm not considering) and I could not determine if it's intended for the replacement market or was designed for an OE fitment that hasn't been announced yet. Dimensionally the H and V are the same, but the V weighs 0.2kg more than the H, indicating some kind of construction difference. Customer service couldn't tell me what the differences are between the two, so they referred me to a product development engineer. Spoke with him yesterday... he was away from the desk and didn't have details at his fingertips but said it would be unusual for the carcass construction to be different between an H and V in the same size within the same line. Believes the difference between these two would solely be in the cap ply material and/or thickness.
Does this sound accurate? A tire maintaining its uniformity throughout its life is a priority for me, and I prefer the concept of a single rayon carcass ply vs. two polyester and will go with the H if there are differences there vs. the V. But if the only difference were in the cap, I'd rather go with the V as it more closely matches the capabilities of the car. In short, if I can go with the V with little to no difference in ride/noise quality vs. the H I will, but I'm also willing to sacrifice the ability to sustain speeds in the 130-149 range (theoretical in the US anyway) if the H provides noticeably more comfort vs. the V. Or, are there other factors I need to consider I haven't yet?
Thanks in advance for any guidance you can provide...
