RE:
First, we've got to get some basics understood:
1) You say you have to transport 250M std. M3/day (approx. 6,130 std M3/min); you further define a temp. & pressure of 50 oC and atmospheric pressure, without stating if these are your "std." conditions. I doubt it, but you leave it up in the air.
2) Presumably, the CO2 exists at 50 oC and 1.0 atmA; and the "standard" conditions are undefined. If you are to give us basic data, you should state your "std" conditions - this is normal, std. engineering practice if you want to deal with specifics - as in your case.
3) Your first option is a 90 km
gas pipeline (note: you don't say supercritical);
4) Your second option is ship it via a tank truck as a liquid; this is routinely done in industry at 250 psig and -8 oF. The conventional tank truck has a max. capacity of 20 tons (net), and the 250M M3/day is equivalent to approx. 460 tons/day (if 20 oC is taken as your "std" condition - see what I mean about stating your base standard?). This means you would require at least 23 tank truck transfers per day - one an hour. This isn't close to being a practical solution.
You could save on the liquid investment by sub-contracting out the hauling of the LCO2; however, you're going to have to face up to an investment in compression and liquefaction (Ammonia; 2-stage) as well as a very healthy storage capacity at the reception end, plus vaporization equipment. On the surface,with the scarce basic data you've supplied, the LCO2 doesn't make economic nor practical sense. Here, I'm stating this with over 15 years of designing, operating and managing LCO2 facilities.
The gas P/L, then, is what is left over as your option. You haven't mentioned going supercritical, but then that P/L version is merely a variance on the gas P/L option. I presume you would compress the 50 oC gas (after cooling it!) up to the pressure to overcome the P/L pressure drop in an optimization case. This all is predicated on what you need at the reception terminal and what it is worth to you. This should be a very nice and educational optimization exercise on P/L size, compressor pressure and energy consumption.
You ask if it is possible to send LCO2 through a P/L. Of course it is - in both the saturated state as well as in the supercritical state. I wouldn't do it in the saturated state because of the
critical properties of CO2. I'll let you use the thermodynamic values at:
there, you will see that it takes less than 88 oF to keep the CO2 liquified - the less the temperature, the less the pressure. However, when you get to a temperature less than your U/G pipeline, you're going to require insulation - and this is probably not practical for a buried pipeline that long.
Which is the best alternative? That is entirely up to you to determine since you own and control all the basic data and economic guidelines and incentives. As you enter the supercritical state, the fluid starts to behave is such a manner that the required pressure drop is normally less than that of the superheated gas. This is where optimization enters the picture in a serious way if your energy prices are high.
I hope this has helped and that I've succeeded in explaining the critical features of this application and its options.
Art Montemayor
Spring, TX
