Ld3Ake
New member
- Nov 9, 2011
- 19
Hi
I want to determine the optimal layup for a carbon composite frame structure but I am new to composite finite element modelling. So far I have just been setting up simple geometries analysing static and buckling load cases that I have been comparing against an aluminium model.
The geometry I am using is essentially a hollow square frame which has been modelled as surfaces. For both the composite and aluminium models the material thickness, loads, constraints and mesh size are identical. The buckling load that is calculated for the aluminiium model is 52kN, whilst the best I can get with the composite model is 43kN. I have definied my material orientation such that the 0' fibers follow the length of the bar, e.g. horizontal orientation definied in x direction, vertical in y direction. I know that to counteract buckling you need +-45 on the outside, which I have done, but I still can't get a frame that is stiffer than the aluminium.
My question is: for a given geometry and single load case, is it possible to determine a layup which results in a higher buckling load than the aluminium model?
